Use the following procedure to display the IPv6 unicast Forwarding Information Base (FIB). The tab shows IPv6 routes from remote Backbone Edge Bridges (BEBs)
- Select SPBM.
- Select the IPv6 Unicast FIB tab.
IPv6 Unicast FIB Field Descriptions
Use the data in the following table to use the IPv6 Unicast FIB tab.
Name |
Description |
VrfId |
Specifies the VRF ID of the IPv6 unicast FIB entry, 0 indicates NRE. |
DestinationIpAddrType |
Specifies the address type of the destination IPv6 address. |
DestinationIpAddr |
Specifies the destination IPv6 Address of the IPv6 unicast FIB entry. |
DestinationMask |
Specifies the destination IPv6 mask of the IPv6 unicast FIB entry |
NextHopBmac |
Specifies the nexthop BMAC of the IPv6 unicast FIB entry. |
DestIsid |
Specifies the destination I-SID of the IPv6 unicast FIB entry. |
Vlan |
Specifies the VLAN of the IPv6 unicast FIB entry. |
Isid |
Specifies the I-SID of the IPv6 unicast FIB entry. |
NextHopName |
Specifies the nexthop hostname of the IPv6 unicast FIB entry. |
OutgoingPort |
Specifies the outgoing port of the IPv6 unicast FIB entry. |
PrefixCost |
Specifies the prefix cost of the IPv6 unicast FIB entry. |
SpbmCost |
Specifies the BMAC cost of the IPv6 unicast FIB entry. |
MetricType |
Specifies the Metric Type of the IPv6 unicast FIB entry. |
